86 Hedlight motor wirering
blazz86 blazz86
I watched Corvette Summer | Posts: 7 | Joined: 08/12
Posted: 01/29/13
03:55 AM
Hi again, I have replaced one of my headlight/mator and the new one only has 5 wires instead of 6, would you be able to point me in the right direction to wire it up.
Thanks again,
Ben.
Posted: 01/29/13
07:37 AM
before we go and rewire your car..
do you still have the original motor assembly....
did just the driven gear strip and need replacing????   the shaft has a worm gear machined into the end.. that drives a big plastic gear with the teeth around the outside.. those plastic gears strip...
with the motor off.. they are easily replaced..
gm as far as i know.. did not put something there that was NOT used.. there are also various devices to control and are controlled by the headlight door motors..
i think you have the WRONG one.. some how.. but i don't know for sure...
there are several articles on headlight door motors...
check this forum post from the  corvette fever  forum on this site..
http://forums.corvettefever.com/70/9354900/c5-corvettes/headlight-problem-help/
i will have to study the wiring for the C4 headlights...
can you supply the GM part numbers off the 6 wire original assembly and the replacement 5 wire assembly..
just because the look alike.. does not mean they are the same...   just last week i drove a friend all the way across los angeles.. to pick up a door for his 69 chevy nova...  the drivers door... when we got there.. all they had was the passenger door.. well it fits why don't you want it..  i wonder if they will realize who filled their gate lock with crazy glue ..
Posted: 01/29/13
07:43 AM
the C4 and firebirds use the same gear... by the way..
blazz86 blazz86
Posted: 01/29/13
08:17 PM
The car only had one light when I bought it and the owner gave me a wreked bonnet with the replacement light, I cant find a part number on the replacement light without having to remove it. From the wireing diagrams I have 84-87 door motors have 3 wires and 88 on have 2 (dark green and grey) the 88 wirering diagram I have is a bit hard to understand. The original motor has a plastic housing and the replacement is cast alloy.
Thanks,
Ben.
Posted: 01/30/13
07:06 AM
i am lost on this as i don't have any of these to examine first hand...
can you examine the bonnet... see if there is a VIN number on it.. you should be able to decode what year it came from... the 10th digit denotes the year..
Years 1980 through 2000 are designated by a letter, beginning with A and ending with Y. The letters I, O, Q, U, and Z are not used, because they can be easily confused with either a number or another letter.
A: 1980
B: 1981
C: 1982
D: 1983
E: 1984
F: 1985
G: 1986
H: 1987
I: not used
J – 1988
K: 1989
L: 1990
M: 1991
N: 1992
O: not used
P: 1993
Q: not used
R: 1994
S: 1995
T: 1996
U: not used
V: 1997
W: 1998
X: 1999
Y: 2000
Z: not used
From 2001 through 2009, numbers were used to designate a vehicle's model year.
1: 2001
2: 2002
3: 2003
4: 2004
5: 2005
6: 2006
7: 2007
8 – 2008
9: 2009
