86 Corvette brakes - VetteWeb Forums at Vette Magazine
86 Corvette brakes
86 Corvette brakes
Cartero Cartero
I watched Corvette Summer | Posts: 11 | Joined: 09/09
Posted: 05/16/12
06:56 PM
I`m working on my wife 86 Vette.Replaced the master cylinder,bleed the brakes but the rear brakes don`t work at all.The front brakes work fine.I think it may be a bad caliper,is there something else i should be looking at?
Posted: 05/16/12
10:30 PM
there is a HUGE section at autozone in the repair info online on bleeding the C4 brakes..
do you happen to have antilocks on yours??? if so.. research is needed..  i don't recall what year they started antilocks..
if you don't have antilocks.. there is a proportioning valve somewhere in the system.  that you will need to depress the button to get fluid to the rear brakes.. something like this
Posted: 05/17/12
07:00 AM
this is from several months ago..
you might want to check out this thread from the other corvette magazine forum on this site..
http://forums.corvettefever.com/70/9140067/c4-corvettes/brakes-1990-base-c-4-brakes/index.html
you will find some links to the az brake bleeding pages on this one..
Posted: 05/19/12
12:09 PM
When all eise fails do it the old school way.
If you can get the car up high enough to get a jack stand at each wheel. You really need to get the wheels and tires off the ground.So you can really see what's going on. Unless you can get it on a drive-on lift.
Starting with the R/Rear caliper (for reference sitting in the driver's seat)open the bleeder,as much as you can without it falling out,and let the brake fluid run until clean brake fluid runs out. Then the L/Rear and the R/Front and the Left/Front...Don't let the master cylinder go empty.If it does you may need to start over.. Be patient..cuz it can take a while this way, but sometime it the best way...
Posted: 05/19/12
12:18 PM
Cartero:
One thing you may want to check first,it just came to me. Make sure your getting brake fluid at the disturbution block. Check it before and after..
NOTE: Once you do this you will have to bleed the brakes...I would go with the old school method. It works and does take time..
